My Dad’s Inky Frame has unfortunately suffered a battery leak which has run straight out the battery case and looks like it’s pickled into a couple of thru holes down by the bottom pin of the expansion header:
(subtle, but look for the green discoloration)
Unfortunately connecting it to USB power makes hosts give overcurrent warnings and what I believe is the voltage regulator on the Pico W heat up (getting a singed finger from one of the adjacent chips trying to hold the BOOTSEL button is what lead to discovering the damage). So this has presumably caused a short somewhere.
- The 3V3 pin on the header has continuity with both other negative pins and the battery negative terminal. (Negative doesn’t have continuity with positive, at least.) Is that expected? The schematic labels negative as ground and 3V3 coming from the Pico’s 3V3OUT pin, so I assume it should instead be positive on normal operation—if so, there’s the problem.
- Is there a reasonable way to peel up the decoration on the back of the board? I’m not sure if it’s a really well-fit vinyl sticker, or actually fused onto the board somehow. It seems that’d be the best way to inspect the damage better and see if there’s a way to fix it. I don’t believe there’s an actual PCB diagram up anywhere to check if corrosion there could cause this?
- And…does anyone have any bright ideas how to cut this short, if my hypothesis is right? It’s a shame to discard the whole board when all the interesting bits (the e-ink display, the pico itself) are probably fine. The expansion header isn’t being used.
- Failing that, is there a reasonable way to at least unmount the display and Pico as spares? Are they mounted with glue?
Thanks…and be careful with those darn double-As out there.
