Setup:
- Inky Impression 13.3” (Spectra 6, EL133UF1)
- Raspberry Pi 5 (Raspberry Pi OS Lite, Debian Trixie)
- Python 3.12, inky package (2.4.0 and 2.5.0)
Debugging:
I run the following Python program to test the panel:
python update.py 255,0,0
import sys
from inky.auto import auto
from PIL import Image
def run():
c = tuple(int(x) for x in sys.argv[1].split(','))
d = auto()
d.set_image(Image.new('RGB', d.resolution, c))
d.show()
run()
The panel updates about a third of the time when I call it. With inky version 2.5.0 I get the following request timeout message when the update fails (2.5.0 contained a fix to properly wait for the busy line: Fix EL133UF1 sending POF mid-refresh on 13.3" displays by stkr22 · Pull Request #265 · pimoroni/inky · GitHub):
inky_el133uf1.py:319: UserWarning: Refresh Wait: Timed out after 65.00s
self._refresh_wait(65.0)
When the screen updates properly, I can see the busy line going from high → low → high. If it doesn’t update it goes from high → low and stays there. I got the busy line info with the following command: watch -n 0.5 pinctrl get 17
Any ideas on what else to try or what might be going wrong?
