Inteligent Gesture Engine APDS-9960 & Algorithms
I have been playing with this breakout quite a lot and finally cracked something I can use.
Idea is a magic mirror carousel but also to checkout if its possible to do more than up, down, left, right.
Haven’t had a look at the arduino examples but the circuit python ones don’t actually use ‘gestures’ just simple leading edge detection, which is equally valid.
I have just done something off the top of my head with the SiN certainty engine where I have bodged full gestures of what is often approx 25 bytes for each direction register.
I am going to have to do some google on pattern recognition and that simple ‘card counting’ algo to maybe geek up on a bit of science.
Anyways what I have expects the flat of your hand and its quite accurate and try and use the longer flat of the little finger edge, always lead the same way and try and keep square to both axis.
If anyone is or has anything been playing with gesture engine ideas like this please share even if its just an article you know of.
The code here is not great I guess as 4 days ago I had totally forgotten (MS doesn’t help) python or any lang but its good enough and being singular its easy to see and tweak what is going on.
Code is here and just install the circuitpython apds9960 examples to grab that great i2c register lib. The actual python example is a bit mweh IMHO and it almost blind sighted into thinking the APDS is not capable of anything but extremely simple edge detection.
This isn’t a intelligent gesture, as its done by me, but pretty sure the SiN certainty engine would be capable of tacking on a few more gestures without gesture bleed and improving this vastly.
Not really interested in coding as yeah its just rough and ready and mainly to give as comprehensive picture of the gesture movement just displayed and somehow you have to think of a way of how to acurately capture that without false signals or bleeds into other gestures.
So yeah if you have any ideas or algorithms what I have here is a ratio of 2 diodes on the same axis and of 15 to 20 plots its expect ratio increments / decrements depending on direction from whatever near to far axis you choose.
If you are accurate with your hand movements you an be accurate with your gesture on a APDS9960 and the code proves that so if anyone has a better gesture detection engine that can run on a Pi0w please give me a shout.
import digitalio
from board import SCL, SDA
from busio import I2C
from adafruit_bus_device.i2c_device import I2CDevice
from adafruit_register.i2c_bits import RWBits
from adafruit_register.i2c_bits import ROBits
from adafruit_register.i2c_bit import RWBit
from adafruit_register.i2c_bit import ROBit
from micropython import const
#pylint: disable-msg=bad-whitespace
#APDS9960_RAM        = const(0x00)
APDS9960_ENABLE     = const(0x80)
APDS9960_ATIME      = const(0x81)
APDS9960_WTIME      = const(0x83)
APDS9960_AILTL     = const(0x84)
APDS9960_AILTH      = const(0x85)
APDS9960_AIHTL      = const(0x86)
APDS9960_AIHTH      = const(0x87)
APDS9960_PILT       = const(0x89)
APDS9960_PIHT       = const(0x8B)
APDS9960_PERS       = const(0x8C)
APDS9960_CONFIG1    = const(0x8D)
APDS9960_PPULSE     = const(0x8E)
APDS9960_CONTROL    = const(0x8F)
APDS9960_CONFIG2    = const(0x90)
APDS9960_ID         = const(0x92)
APDS9960_STATUS     = const(0x93)
APDS9960_CDATAL     = const(0x94)
APDS9960_CDATAH     = const(0x95)
APDS9960_RDATAL     = const(0x96)
APDS9960_RDATAH     = const(0x97)
APDS9960_GDATAL     = const(0x98)
APDS9960_GDATAH     = const(0x99)
APDS9960_BDATAL     = const(0x9A)
APDS9960_BDATAH     = const(0x9B)
APDS9960_PDATA      = const(0x9C)
APDS9960_POFFSET_UR = const(0x9D)
APDS9960_POFFSET_DL = const(0x9E)
APDS9960_CONFIG3    = const(0x9F)
APDS9960_GPENTH     = const(0xA0)
APDS9960_GEXTH      = const(0xA1)
APDS9960_GCONF1     = const(0xA2)
APDS9960_GCONF2     = const(0xA3)
APDS9960_GOFFSET_U  = const(0xA4)
APDS9960_GOFFSET_D  = const(0xA5)
APDS9960_GOFFSET_L  = const(0xA7)
APDS9960_GOFFSET_R  = const(0xA9)
APDS9960_GPULSE     = const(0xA6)
APDS9960_GCONF3     = const(0xAA)
APDS9960_GCONF4     = const(0xAB)
APDS9960_GFLVL      = const(0xAE)
APDS9960_GSTATUS    = const(0xAF)
# APDS9960_IFORCE     = const(0xE4)
APDS9960_PICLEAR    = const(0xE5)
APDS9960_CICLEAR    = const(0xE6)
APDS9960_AICLEAR    = const(0xE7)
APDS9960_GFIFO_U    = const(0xFC)
# APDS9960_GFIFO_D    = const(0xFD)
# APDS9960_GFIFO_L    = const(0xFE)
# APDS9960_GFIFO_R    = const(0xFF)
DEVICE_ADDRESS      = const(0x39)
ROUTINE_PROXIMITY   = const(0x01)
ROUTINE_A_CLS       = const(0x02)
ROUTINE_GESTURE     = const(0X03)
#pylint: enable-msg=bad-whitespace
def calculate_color_temperature(r, g, b):
    """Converts the raw R/G/B values to color temperature in degrees Kelvin"""
    #  1. Map RGB values to their XYZ counterparts.
    #   Based on 6500K fluorescent, 3000K fluorescent
    #    and 60W incandescent values for a wide range.
    #    Note: Y = Illuminance or lux
    x = (-0.14282 * r) + (1.54924 * g) + (-0.95641 * b)
    y = (-0.32466 * r) + (1.57837 * g) + (-0.73191 * b)
    z = (-0.68202 * r) + (0.77073 * g) + (0.56332 * b)
    #  2. Calculate the chromaticity co-ordinates
    xchrome = x / (x + y + z)
    ychrome = y / (x + y + z)
    #  3. Use   to determine the CCT
    n = (xchrome - 0.3320) / (0.1858 - ychrome)
    #  4. Calculate the final CCT
    cct = (449.0 * pow(n, 3)) + (3525.0 * pow(n, 2)) + (6823.3 * n) + 5520.33
    #    Return the results in degrees Kelvin
    return cct
def calculate_lux(r, g, b):
    """Calculate ambient light values"""
    #   This only uses RGB ... how can we integrate clear or calculate lux
    #   based exclusively on clear since this might be more reliable?
    illuminance = (-0.32466 * r) + (1.57837 * g) + (-0.73191 * b)
    return illuminance
class DeviceControl: #pylint: disable-msg=too-few-public-methods
    def __init__(self, i2c):
        self.i2c_device = i2c
    device_enable = RWBit(APDS9960_ENABLE, 0)
    deviceID = ROBits(8, APDS9960_ID, 0)
    # Shared register block
    proximity_gesture_led_boost = RWBits(2, APDS9960_CONFIG2, 4)
    proximity_gesture_saturation = ROBit(APDS9960_STATUS, 6)
    c_als_proximity_persistance = RWBits(4, APDS9960_PERS, 4)
    all_non_gesture_interupt_clear = ROBits(8, APDS9960_AICLEAR, 0)
    # Proximity register block
    proximity_enable = RWBit(APDS9960_ENABLE, 2)
    proximity_interrupt_enable = RWBit(APDS9960_ENABLE, 5)
    proximity_low_threshold = ROBits(8, APDS9960_PILT, 0)
    proximity_high_threshold = ROBits(8, APDS9960_PIHT, 0)
    proximity_pulse_length = RWBits(2, APDS9960_PPULSE, 6)
    proximity_pulse_count = RWBits(6, APDS9960_PPULSE, 0)
    proximity_gain_control = RWBits(2, APDS9960_CONTROL, 2)
    proximity_led_drive_strength = RWBits(2, APDS9960_CONTROL, 6)
    proximity_saturation_interupt_enable = RWBit(APDS9960_CONFIG2, 7)
    proximity_interupt = ROBit(APDS9960_STATUS, 5)
    proximity_valid = ROBit(APDS9960_STATUS, 1)
    proximity_data = ROBits(8, APDS9960_PDATA, 0)
    proximity_offset_up_right = ROBits(8, APDS9960_POFFSET_UR, 0)
    proximity_offset_down_left = ROBits(8, APDS9960_POFFSET_DL, 0)
    proximity_gain_compensation_enable = RWBit(APDS9960_CONFIG3, 5)
    proximity_mask_up_enable = RWBit(APDS9960_CONFIG3, 3)
    proximity_mask_down_enable = RWBit(APDS9960_CONFIG3, 2)
    proximity_mask_left_enable = RWBit(APDS9960_CONFIG3, 1)
    proximity_mask_right_enable = RWBit(APDS9960_CONFIG3, 0)
    proximity_interupt_clear = RWBits(8, APDS9960_PICLEAR, 0)
    # Color / ALS register block
    c_als_enable = RWBit(APDS9960_ENABLE, 1)
    c_als_interupt_enable = RWBit(APDS9960_ENABLE, 4)
    c_als_wait_enable = RWBit(APDS9960_ENABLE, 3)
    c_als_adc_integration_time = RWBits(8, APDS9960_ATIME, 0)
    c_als_wait_time = RWBits(8, APDS9960_WTIME, 0)
    c_als_low_threshold_lower_byte = RWBits(8, APDS9960_AILTL, 0)
    c_als_low_threshold_upper_byte = RWBits(8, APDS9960_AILTH, 0)
    c_als_high_threshold_lower_byte = RWBits(8, APDS9960_AIHTL, 0)
    c_als_high_threshold_upper_byte = RWBits(8, APDS9960_AIHTH, 0)
    c_als_wait_long_enable = RWBit(APDS9960_CONFIG1, 1)
    c_als_gain_control =  RWBits(2, APDS9960_CONTROL, 0)
    c_als_clear_diode_saturation_interupt_enable = RWBit(APDS9960_CONFIG2, 6)
    c_als_clear_diode_saturation = ROBit(APDS9960_STATUS, 7)
    c_als_interupt = ROBit(APDS9960_STATUS, 4)
    c_als_valid = ROBit(APDS9960_STATUS, 0)
    c_als_clear_channel_interupt_clear = RWBits(8, APDS9960_CICLEAR, 0)
    # Gesture register block
    gesture_enable= RWBit(APDS9960_ENABLE, 6)
    gesture_entry_threshold = RWBits(8, APDS9960_GPENTH, 0)
    gesture_exit_threshold = RWBits(8, APDS9960_GEXTH, 0)
    gesture_fifo_threshold = RWBits(2, APDS9960_GCONF1, 6)
    gesture_exit_mask = RWBits(4, APDS9960_GCONF1, 2)
    gesture_exit_persistance = RWBits(2, APDS9960_GCONF1, 0)
    gesture_gain_control = RWBits(2, APDS9960_GCONF2, 5)
    gesture_led_drive_strength = RWBits(2, APDS9960_GCONF2, 3)
    gesture_wait_time = RWBits(3, APDS9960_GCONF2, 0)
    gesture_offset_up = RWBits(8, APDS9960_GOFFSET_U, 0)
    gesture_offset_down = RWBits(8, APDS9960_GOFFSET_D, 0)
    gesture_offset_left = RWBits(8, APDS9960_GOFFSET_L, 0)
    gesture_offset_right = RWBits(8, APDS9960_GOFFSET_R, 0)
    gesture_pulse_count = RWBits(6, APDS9960_GPULSE, 0)
    gesture_pulse_length = RWBits(2, APDS9960_GPULSE, 6)
    gesture_dimension_select = RWBits(2, APDS9960_GCONF3, 0)
    gesture_fifo_clear= RWBit(APDS9960_GCONF4, 2)
    gesture_interupt_enable= RWBit(APDS9960_GCONF4, 1)
    gesture_mode = RWBit(APDS9960_GCONF4, 0)
    gesture_fifo_level = RWBits(8, APDS9960_GFLVL, 0)
    gesture_fifo_overflow = ROBit(APDS9960_GSTATUS, 1)
    gesture_valid = ROBit(APDS9960_GSTATUS, 0)
#pylint: enable-msg=too-few-public-methods
# The follow is for I2C communications
comm_port = I2C(SCL, SDA)
device = I2CDevice(comm_port, DEVICE_ADDRESS)
registers = DeviceControl(device)
# Raise error if deviceID not found
if registers.deviceID != 0xAB:
    raise RuntimeError()
# Choose routine and change below line ROUTINE_PROXIMITY ROUTINE_A_CLS ROUTINE_GESTURE
routine = ROUTINE_GESTURE
# Device Power ON
registers.device_enable = 0x01
if routine == ROUTINE_PROXIMITY:
    registers.c_als_enable = 0x00
    registers.gesture_enable = 0x00
    registers.proximity_enable = 0x01
    registers. proximity_interrupt_enable = 0x00
    #registers.proximity_low_threshold = 0x00
    #registers.proximity_high_threshold = 0xFF
    registers.c_als_proximity_persistance = 0x00
    #registers.proximity_pulse_length = 0x00
    #registers.proximity_pulse_count = 0x00
    registers.proximity_gain_control = 0x00
    registers.proximity_led_drive_strength = 0x00
    #registers.proximity_saturation_interupt_enable = 0x00
    registers.proximity_gesture_led_boost = 0x00
    #registers.proximity_offset_up_right = 0x00
    #registers.proximity_offset_down_left = 0x00
    #registers.proximity_gain_compensation_enable = 0x00
    #registers.proximity_mask_up_enable = 0x00
    #registers.proximity_mask_down_enable = 0x00
    #registers.proximity_mask_left_enable = 0x00
    #registers.proximity_mask_right_enable = 0x00
    print("all_non_gesture_interupt_clear {}".format(registers.all_non_gesture_interupt_clear))
        print("Data: {}; Valid: {}; Saturation: {}; Interupt: {}; Interupt Clear: {}".format(registers.proximity_data, registers.proximity_valid, registers.proximity_gesture_saturation, registers.proximity_interupt, registers.proximity_interupt_clear))
elif routine == ROUTINE_A_CLS:
    registers.proximity_enable = 0x00
    registers.c_als_enable = 0x01
    registers.c_als_gain_control = 0x00
    registers.c_als_adc_integration_time = 0x01
        #wait for color data to be ready
        while not registers.c_als_valid:
            time.sleep(0.005)
        buf = bytearray(2)
        buf[0] = APDS9960_CDATAL
        device.write(buf, end=1, stop=False)
        device.readinto(buf)
        c = buf[1] << 8 | buf[0]
        buf[0] = APDS9960_RDATAL
        r = buf[1] << 8 | buf[0]
        buf[0] = APDS9960_BDATAL
        b = buf[1] << 8 | buf[0]
        buf[0] = APDS9960_GDATAL
        g = buf[1] << 8 | buf[0]
        print("red: ", r)
        print("green: ", g)
        print("blue: ", b)
        print("clear: ", c)
        print("color temp {}".format(calculate_color_temperature(r, g, b)))
        print("light lux {}".format(calculate_lux(r, g, b)))
        time.sleep(0.5)
elif routine == ROUTINE_GESTURE:
    registers.proximity_gain_control = 0x03
    registers.gesture_wait_time = 0x02
    registers.gesture_entry_threshold = 0x0C
    registers.gesture_exit_threshold = 0x0C
    registers.gesture_fifo_threshold = 0x00
    #registers.gesture_exit_mask = 0x00
    registers.gesture_exit_persistance = 0x00
    registers.gesture_gain_control = 0x03
    registers.gesture_led_drive_strength = 0x00
    proximity_gesture_led_boost = 0x03
    #registers.gesture_pulse_count = 0x40
    #registers.gesture_pulse_length = 0x01
    #registers.gesture_dimension_select = 0x00
    #registers.gesture_offset_up = 0x00
    #registers.gesture_offset_down = 0x00
    #registers.gesture_offset_left = 0x00
    #registers.gesture_offset_right = 0x00
    registers.gesture_enable = 0x01
    first = 0
    buffer = bytearray(129)
        if registers.gesture_mode == 0:
            if first == 0:
                print ("---------------------------------------------------------------")
            first = 1
            left_right_direction = 0
            up_down_direction = 0
            left_right_valid_count = 0
            up_down_valid_count = 0
            last_left_right_ratio = 1
            last_up_down_ratio = 1
            gesture_count = 0
            dataset_count = 0
        else:
            first = 0
            datasets = registers.gesture_fifo_level
            while datasets > 0:
                print("Datasets: {}".format(datasets))
                buffer[0]= APDS9960_GFIFO_U
                device.write(buffer, end=1, stop=False)
                device.readinto(buffer, start=1, end=(datasets *4) + 1)
                x = 0
                #print ("Len gesture: {}".format(len(gesture)))
                while x < datasets:
                    up =  max(1, buffer[1 + (x * 4)])
                    down = max(1, buffer[2 + (x * 4)])
                    left = max(1, buffer[3 + (x * 4)])
                    right = max(1, buffer[4 + (x * 4)])
                    left_right_ratio = left / right
                    up_down_ratio = up / down
                    gesture_count = gesture_count + 1
                    if x < 2 and dataset_count == 0:
                        left_right_valid_count = left_right_valid_count + 1
                        up_down_valid_count = up_down_valid_count + 1
                        if min(last_left_right_ratio, left_right_ratio) < 1:
                            left_right_direction = 1
                        else:
                            left_right_direction = -1
                        if min(last_up_down_ratio, up_down_ratio) < 1:
                            up_down_direction = 1
                        else:
                            up_down_direction = -1
                        last_left_right_ratio = left_right_ratio
                        last_up_down_ratio = up_down_ratio
                        if x == 1 and dataset_count == 0:
                               if left_right_direction == 1:
                                   last_left_right_ratio = min(last_left_right_ratio, left_right_ratio)
                               else:
                                   last_left_right_ratio = max(last_left_right_ratio, left_right_ratio)
                               if up_down_direction == 1:
                                   last_up_down_ratio = min(last_up_down_ratio, up_down_ratio)
                               else:
                                   last_up_down_ratio = max(last_up_down_ratio, up_down_ratio)
                    else:
                            if last_left_right_ratio < left_right_ratio:
                        else:
                            if last_left_right_ratio > left_right_ratio:
                            if last_up_down_ratio < up_down_ratio:
                        else:
                            if last_up_down_ratio > up_down_ratio:
                    print("Up:{:3d} Down: {:3d} | Left: {:3d} Right: {:3d} | up_down_ratio: {:03.2f} | left_right_ratio: {:03.2f}".format(up, down, left, right, up_down_ratio, left_right_ratio))
                    x = x + 1
                up_down_certainty = up_down_valid_count / gesture_count
                left_right_certainty = left_right_valid_count / gesture_count
                print("Up_down_direction: {:3d} Count {:4d} Certainity {:03.2f} | Left_right_direction: {:3d} Count {:4d} Certainity {:03.2f}".format(up_down_direction, up_down_valid_count, up_down_certainty, left_right_direction, left_right_valid_count, left_right_certainty))
                dataset_count = dataset_count + 1
