Hi all,
Recently lost the use of my right hand (severed radial nerve). I work in IT, mostly in the terminal! continuously pressing various key commands and thought the keybow would be an excellent aid while my hand is out of action.
I struggle at the moment with certain key combinations involving alt or control, or pressing right shift and using the scroll wheel for zooming. So I thought I’d map out these keys onto a separate peripheral to avoid my hand splatting over multiple keys and accidentally hitting enter.
I formatted an 8G SD card I’ve previously used in a RPi3. Copied over the Keybow files from the instructions and fired up the Pi Zero.
No lights on either the Pi or the key switches. Windows detects the device as a “BCM2708 Boot” but doesn’t want to do anything else with it.
I’ve tried formatting and repeating the procedure with another 64GB card, swapping USB ports, directly on computer, through a passive hub and also through a powered hub and no luck.
Have I missed anything?
