Problem:
I try to install Picade on Recalbox but the Terminal says “Running as root, please log in as a regular user with sudo rights!” after ich typed curl -sS https://get.pimoroni.com/picadehat | bash
Looks like RecalboxOS uses a version of the stat tool which is not compatible with the picadehat installation script. The error is happening in line 285 of the script:
space_chk() {
if command -v stat > /dev/null && ! $IS_MACOSX; then
if [ $spacereq -gt $(($(stat -f -c “%a*%S” /)/10**6)) ];then
fi
fi
This part checks if you have sufficient disk space for the picadehat installation. It fails because stat -f does not work on your system (RecalboxOS’s stat says invalid option -- 'f' in your screenshot). This means that the tool stat is a different version or a different program altogether.
If you are sure that you have enough disk space, you could:
download the script with curl -sSO https://get.pimoroni.com/picadehat
open the downloaded file picadehat and comment out the entire function body with “#” like this:
space_chk() {
# if command -v stat > /dev/null && ! $IS_MACOSX; then
# if [ $spacereq -gt $(($(stat -f -c “%a*%S” /)/10**6)) ];then
# fi
# fi
run the installation script with bash picadehat
However, this only works if the stat incompatibilty is the only problem. There may be other similar problems.
