I have a new picade. When I turn it on, the screen shows vertical stripes where the splash screen should be:
When I plug the included HDMI cable into another monitor, that works—I’ve set up wifi and sorted out my config.txt and all from there. So I’m pretty sure the problem is between the HDMI cable and the display panel: either a bad board, a bad ribbon cable, or a badly inserted ribbon cable. I’ve re-seated the ribbon cable five times. It now looks like this:
{redacted, because new users can only put one image in a post}
Is that plausibly right? What should it look like? What else should I try while debugging?
Thanks,
Brian
