Just got a Frame for the Raspberry Pi 7" Touchscreen Display (lovely purple colour!).
One of the legs is fine, but the other is about 0.5mm thicker, so is too large to fit the mounting holes in the rest of the frame. Is this a known problem, and is there a known solution?
no, I think it’s merely a consequence of the tolerance in thickness of the material. Unfortunately it’s not practical to check all the parts fit as designed on every units and I guess once in a while such a problem may occur.
… if you shoot support@pimoroni.com an email I’m sure they can sort you out a couple of feet with appropriate thickness. Sorry for the trouble.
