OnOff and LiPo SHIM - soldering
Hi all,
does every pin on these SHIMs need to be soldered to the GPIO or just selected ones? Don’t want to do more work than is needed, or apply more heat than necessary :-)
Rob
You can likely get away with only soldering the pins used. They should be far enough apart that the boards won’t move when a button is pressed etc.
