OnOff Shim will not shutdown libgpiod2 installed
OnOff Shim on a Pi 4 Bookworm with updated BCM GPIO libgpiod2 software will not shutdown. Shim was working correctly when using Bullseye. Shim daemon appeared to load correctly/completely. Is there an updated daemon to fix this issue?
Will there ever be a 3/5 amp version?
I do believe the Picade Hat will handle that current? For a Pi 4 power supply anyway. And it also has on off / shutdown functions for a Pi 4.
Picade X HAT USB-C
