Hi folks,
I just received my Raspi Zero W and the pHAT DAC, installed Raspbian Stretch Lite, changed the sudo user to a different name than pi and followed the tutorial to install the dac libraries (https://learn.pimoroni.com/tutorial/phat/raspberry-pi-phat-dac-install)
However, when I run
curl https://get.pimoroni.com/phatdac | bash
for a second time, I’m getting the following error when testing the speaker:
speaker-test 1.1.3
Playback device is default
Stream parameters are 48000Hz, S16_LE, 2 channels
WAV file(s)
ALSA lib confmisc.c:767:(parse_card) cannot find card ‘0’
ALSA lib conf.c:4528:(_snd_config_evaluate) function snd_func_card_driver returned error: No such file or directory
ALSA lib confmisc.c:392:(snd_func_concat) error evaluating strings
ALSA lib conf.c:4528:(_snd_config_evaluate) function snd_func_concat returned error: No such file or directory
ALSA lib confmisc.c:1246:(snd_func_refer) error evaluating name
ALSA lib conf.c:4528:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:5007:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM default
Playback open error: -2,No such file or directory
boot/config.txt looks good to me. Does anyone have an idea what could have went wrong?
Many thanks in advance for your support :-)
