pHAT DAC - mixing stereo to mono (mpd/alsa)?
I’ve seen this other topic, but that didn’t seem to work for me.
Set-up:
  • Raspberry Pi Zero W (Jessie 4.9)
  • pHAT DAC (Pimoroni standard install)
I’m just streaming a single internet radio channel using mpd (and mpc directly in the command line) and that works fine for stereo. However I’m going to build this into an old radio with a single speaker, so I’d like to mix the stereo to mono. And I’d prefer to do it in software rather than hardware, just to be elegant… :)
I tried changing /etc/asound.conf to the following (as described in this post):
pcm.card0 {
  type hw
  card 0
ctl.card0 {
  type hw
  card 0
pcm.monocard {
  slave.pcm card0
  slave.channels 2
  type route
  ttable {
    # Copy both input channels to output channel 0 (Left).
    0.0 0.5
    1.0 0.5
    # Send nothing to output channel 1 (Right).
    0.1 0
    1.1 0
ctl.monocard {
  type hw
  card 0
pcm.!default monocard
ctl.!default monocard
But after a reboot I get no audio at all and the mpc and mpc stop commands are met with "ERROR: Failed to open audio output".
The only /etc/asound.conf that produces audio for me is the Pimoroni pHAT DAC standard one of…
pcm.!default  {
 type hw card 0
ctl.!default {
 type hw card 0
…which doesn’t do any stereo->mono mixing.
Any ideas?
Hmm, interesting. What do you see if you run:
asound -L
asound -l
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: sndrpihifiberry [snd_rpi_hifiberry_dac], device 0: HifiBerry DAC HiFi pcm5102a-hifi-0 []
  Subdevices: 0/1
  Subdevice #0: subdevice #0
…and…
aplay -L
null
    Discard all samples (playback) or generate zero samples (capture)
sysdefault:CARD=sndrpihifiberry
    snd_rpi_hifiberry_dac,
    Default Audio Device
dmix:CARD=sndrpihifiberry,DEV=0
    Direct sample mixing device
dsnoop:CARD=sndrpihifiberry,DEV=0
    Direct sample snooping device
hw:CARD=sndrpihifiberry,DEV=0
    Direct hardware device without any conversions
plughw:CARD=sndrpihifiberry,DEV=0
    Hardware device with all software conversions
I was just assuming you need aplay output, not asound… Does everything look ok here?
Oh yes, I did. D’oh!
I expected to see a “monocard” output, I wonder if there’s something up with the asound.conf that I can’t spot. I’ll see if I can rig up a test for this tomorrow if I remember!
You’re probably far from the only person who’s likely to want to downmix to mono.
Ah, ok, my turn to d’oh: the above aplay output is using the standard Pimoroni asound.conf. When using the stereo mono mixing one, I get this output:
aplay -l
  Subdevices: 0/1
…and…
aplay -L
null
monocard
And… guess what? Today that same file works! I get audio and ok level just on left channel, so I assume the asound.conf is doing its job correctly!
Dunno why that didn’t work before, maybe a copy and paste error, anyway, works now. Thanks for your help anyway :)
Excellent! Glad you’re up and running.
