Do some keys not work, or is something more weird/intermittent happening?
You should be able to reset keybinding without reinstalling, but I can never remember how.
Hiya again,
Sorted it out late last night, it was just a faulty micro-switch. The picade PCB seems 100% fine and functioning as expected with the headphone detection switched off.
Did you guys figure out why the headphone detection is getting tripped by line input?
Thanks very much for your help and support sorting it out! :)
I tried picade_v2.3_no-headphone-detect.hex and it works perfectly with phat-dac now. Not sure if headphone port works but I do not use it.
Thanks for the help.
the headphone will ‘work’ but it won’t cut out the output to speaker, which is essentially what the problem can be with the regular firmware, with some sources it seems - it will erroneously trigger the silencing of the amp output.
