Phatbeat configuration for mopidy
Hi, I followed this guide (Streaming Spotify to your Pi) to install Mopidy on Pirate Radio.
The default volume level was very (very!) loud so I opened the config file (/etc/mopidy/mopidy.conf) and found an error as it was using the ‘software’ mixer instead of ‘alsamixer’.
My config file now is:
[audio]
mixer = alsamixer
[alsamixer]
enabled = true
card = 0
control = Master
Now the output volume level is in sync with ALSA and I can change it with alsamixer in ssh.
The problem is that now I can’t find the name of the ALSA control to use inside mopidy.
Sep 15 17:30:51 pirateradio mopidy[493]: ERROR    [MainThread] mopidy.commands Mixer (AlsaMixer) initialization error: Could not find ALSA mixer control Master on card 0. Known mixers on card 0 include:
As you can see known mixers on card 0 are none! If I run this command (according to GitHub - mopidy/mopidy-alsamixer: Mopidy extension for ALSA volume control):
pi@pirateradio:~ $ amixer scontrols
Simple mixer control 'Master',0
Simple mixer control 'Capture',0
Maybe the problem is that I’m using Pulseaudio?
I answer to myself… The problem is that the index for ‘sndrpihifiberry’ in alsa is ‘-1’ but is not a valid integer for the mopidy_alsamixer plugin.
So I’ve modified line 21 in /usr/lib/python3/dist-packages/mopidy_alsamixer/__init__.py to:
schema["card"] = config.Integer(minimum=-1)
now I can use the right config in /etc/mopidy/mopidy.conf:
[audio]
mixer = alsamixer
[alsamixer]
enabled = true
card = -1
control = Master
Now I finally can set the right volume from iris and from the side buttons!
