For some odd reason my python camera application causes a kernel panic and only runs for a few minutes.
Can any one spot any mistakes?
# Core Python Liberies
import logging
import os
import json
import datetime
# Non Core Phyton Liberies
from picamera import PiCamera
from picamera import Color
# sudo apt-get install python3-picamera
# Variable Declaration
dictionary_config = {}
# Object Declaration
camera = PiCamera()
# Application Runs From Here
if __name__ == '__main__':
try:
# Change Runtime Directory
try:
variable_path = os.path.dirname(os.path.realpath(__file__))
os.chdir(variable_path)
except:
exit('Runtime Directory Change Failed')
# Load Application Configeration Dictionary
try:
if (os.path.isfile('config.json')):
try:
object_file = open('config.json', 'r')
dictionary_config = json.load(object_file)
object_file.close()
except Exception as variable_exception:
exit(variable_exception)
else:
logging.error('Application Config File Not found')
exit(1)
# Logging
try:
if(len(dictionary_config['application']['log_level']) <= 0):
dictionary_config['application']['log_level'] = 'DEBUG'
dictionary_config['application']['log_file'] = ''
if (os.path.isfile('debug.console')):
logging.basicConfig(filename = dictionary_config['application']['log_file'], level = dictionary_config['application']['log_level'].upper(), format='%(asctime)s - %(levelname)s - %(message)s')
logging.error(variable_exception)
# Display
logging.info('Application')
logging.info(' ')
logging.info('Version:')
logging.info(' %s' %(dictionary_config['application']['version']))
logging.info(' ')
logging.info('Log Level:')
logging.info(' %s' %(dictionary_config['application']['log_level']))
logging.info(' ')
logging.info('Log File:')
logging.info(' %s' %(dictionary_config['application']['log_file']))
logging.info(' ')
# Startup Delay
try:
time.sleep(int(dictionary_config['application']['application_startup_delay']))
# Watch Directory
if (os.path.isdir(dictionary_config['images']['export_directory'])):
logging.info('Export Directory:')
logging.info(' %s' %(dictionary_config['images']['export_directory']))
else:
logging.error('Export Directory Not found')
exit(1)
logging.info(' ')
# Camera Configeration
logging.info('Camera Configeration:')
try:
# Camera
for variable_dictionary_section in dictionary_config['camera']:
logging.info('%s:' %(variable_dictionary_section.title() ))
try:
variable_temp = int(dictionary_config['camera'][variable_dictionary_section])
variable_temp = str(dictionary_config['camera'][variable_dictionary_section])
try:
setattr(camera, variable_dictionary_section, variable_temp)
logging.info(' %s' %(str(getattr(camera, variable_dictionary_section))))
# Annotate
camera.annotate_text = dictionary_config['camera_annotate']['annotate_text']
camera.annotate_text_size = int(dictionary_config['camera_annotate']['annotate_text_size'])
camera.annotate_foreground = Color(dictionary_config['camera_annotate']['annotate_foreground'])
camera.annotate_background = Color(dictionary_config['camera_annotate']['annotate_background'])
logging.info(' ')
# Display
logging.info('Camera Warm Up 0.5s')
logging.info(' ')
# Delay For Camera warm Up
time.sleep(0.5)
# Application Loops From Here
try:
if (os.path.isfile('snap.action')):
logging.info(' ')
logging.info('----- ----- -----')
# Analytics
variable_date_time_start = time.perf_counter_ns()
variable_temp = dictionary_config['camera_annotate']['annotate_text'] + ' - ' + datetime.datetime.now().strftime('%d-%m-%Y %H-%M-%S')
camera.annotate_text = variable_temp
camera.capture(dictionary_config['images']['export_directory'] + variable_temp + '.jpg', 'jpeg', True)
logging.info('snap')
os.remove('snap.action')
# Analytics
variable_date_time_end = time.perf_counter_ns()
logging.info(' ')
logging.info('Elapsed Time: %dms' %((variable_date_time_end - variable_date_time_start) / 1000000))
finally:
# Release Camera
try:
logging.info('Camera Release')
camera.close()
