tried to fit the cable and a small bit of plastic shot off the board. Is the clip broken?
I am not sure if the cable is in the right place. Do you have any pictures.of how to fit very unclear from the video
Stugging a bit with the 10 inch screen I assuming from the instructions the top tab in not connected to the screen. Having a bit of an issue lining it up. Can you help with these issues. I have pictures if that helps
I seem to remember a similar post a while back? I don’t think the clip is broken, its just that the locking bar is different on some of the newer displays. Underneath instead of on top or something?
I’ve only ever used the ones on the Pi for the display and camera. The cable bottoms out and only goes in so far with the locking bar open. I just look to make sure it straight and level before locking it in. They don’t go in all that far. If it doesn’t work have another try.
Just take your time and be careful. The ones on the Pi can break if your too ham fisted with them. I haven’t broken one yet, knock on wood.
Only what I found above. I don’t work for or have any ties to Pimoroni, just so you know.
Just a forum member that likes to help out when I can.
The ones on the Pi I open very gently with my fingernails. One finger on each end.
If the bar just came off without getting broken in the process, in theory it should just snap back in place and be fine. Looks like you lucked out and its good. :)
