I just finished building a Pimoroni Picade Cabinet Kit - 10" Display (PIM469) unfortunately it looks like the screen or HDMI driver board is defective.
I’m pretty sure the assembly is correct (picture attached) to make sure I haven’t done anything stupid in the connection.
some facts:
Running off an 18w USB-C power supply from iPhone 11Pro. I have also tried running the screen alone from a 2.1w USB power supply.
Screen backlight turns on once the raspberry pi boot up. Power light on the driver board comes on too.
Screen backlight turns off after about 10 secs. Power can be turned on again with the control board tactile switched but again, turns off after 10 secs.
Screen Menu and L/R buttons on the control board do nothing.
I have tried booting the raspberry pi connecting to a different HDMI monitor and the raspberry Pi and retroPi image is OK.
On my system the menu button on the control panel only works when there’s an image on screen. When there’s no image I can turn the screen off & on via the panel, and when it’s on, pressing the Exit button brings up a DVI / HDMI menu.
Have you tried connecting anything else to the HDMI socket on the control board?
Just so you know, I don’t own a Picade, or that display. Not yet anyway, its on my wish list though.
Anyway, if you go here https://shop.pimoroni.com/pages/contact-us
You can e-mail Pimoroni tech support directly with your issue. I’d put a link to this thread in that e-mail. Then see what they have to say.
I had the same screen problem with my 10" picade raspberry 4. I lost 4 hours of my life trying to get the screen to work ;)
In the end, I just went to the store to buy a new mini hdmi to hdmi cable (I went through something like that on google sooner that afternoon) and it SOLVED my screen problem :)))
The factory adaptator and cable were bad.
Hope this will help, it took me 10hrs to get the picade working with the 10" screen and the raspberry 4!!!
