I purchased a Picade HAT for the power on and safe shutdown functionality. I’m beginning the build and I have some questions.
Am I correct in my understanding that I still need to use the Picade PCB for the speaker connections and volume buttons?
To use the Picade HAT power on and safe shutdown functionality, do I need to add an additional button to the Picade? Can I power on and off the Picade through a button combination or do I need a dedicated button?
If I still need to use the Picade PCB, what is the ideal button and joystick wiring? Should I wire the joystick and buttons to the Picade HAT or Picade PCB?
Thank you to all replies.
