(I had put this in the picade section, but it’s gone uncommented over there)
I seem to have an issue with the Picade PCB, none of my buttons are detected by the picade and if I connect it to a PC via USB it doesn’t seem to show up as anything.
When your in the emulation station menu and press a button on the picade, do you get a light on the picade PCB? (i/e, you press a button, a light comes on, you release button, light goes off)
I’m using a 5V/2A USB adaptor, but have tried a couple of other adaptors including separate power cables to the screen & Pi. When the Picade has power, ON is lit, and when I press reset BL/Bootloader flashes for a few seconds. I don’t see any activity on the TX/RX lights on button presses for anything.
Sorry to wake up such an old topic but I am having the same issue with the supplied USB cable not working. If I use the supplied cable only the amp works. But borrowing the USB cable from my tablet fixes the issue.
I actually purchased my picade through modmypi, but after a week I am still awaiting a respondent(probably due to a back log as the pi3 has just been released as they are normally fast to respond). Its a short red usb cable and does not work with Linux and my pi3 or windows.
