Picade Max USB Audio uf2 flash failure
Picade Max USB Audio board connected to a Pi 5.
I went here,
and folowed the Updating the firmware for the board
After extracting the picade-max-audio.uf2, I put the Max Audio in Boot Mode and did the drag and drop. Blue LED is on, Red Led is on, and the Green LED just continuously blinks. Even after a reset? Same thing if I unplug the USB cable, and plug it back in.
Redownloaded the uf2 and repeated the above with the same results. =(
OK, some progress. Going back one to 0.0.4 has it trying to work. I get sound but every few seconds the LED flashed bright white and now my mouse won’t work? And I now have the USB over current detected lightning bolt showing? I am using the official Raspberry Pi 45W USB-C Power Supply
Ok, I went here,
and flashed with
picade-max-audio-74552e0315831acb31dc6e062360b1930891bf6f.uf2
and all seems good now. Everything is working and no lockups in YouTube.
