Hello,
I’m a bit new to tech. I’m wondering if it is possible to connect any device to the picade screen, I have a project in mind using the PlayStation tv
It will run off of pretty well any HDMI signal in. It’s basically just a monitor minus the case. It doesn’t have to be connected to a Raspberry Pi. That’s assuming you plan on using the driver board etc that comes with it. Other than that you’ll need a 5V power supply to power it.
