Picade X HAT USB-C with Picade 10" inverted screen on RetroPie
Hello folks,
after upgrading my Picade 8" to Picade 10" with the Picade X HAT USB-C and a Raspberry Pi4 I’m unable to use EmulationStation/Retropie, the screen is flipped upon booting and adding command like “display_hdmi_rotate=0x20000” solves the issue but works only under the legacy non-GL driver, which prevents Emulationstation from starting, whereas if I enable “dtoverlay=vc4-fkms-v3d”, Emulationstation does then start but the screen won’t flip.
I’m at a loss here, tried multiple combinations and it seems that there is no straightforward way to flip the screen using “display_hdmi_rotate” under these GL drivers, I read somewhere that a batch of these Picade X HAT were impacted with this screen inverted issue (*which I didn’t had before with the Picade 8" set).
Was able to replicate this with both RPi 3b+ and RPi4.
Any suggestions, tips, workarounds, highly welcomed!
Hi Rodrijk.
Did you ever get this resolved? We are trying to set up a Picade now for the first time (with a 10" screen) on a Pi4 (Model B Rev 1.1) and have been spending 3 frustrating evenings concluding the exact same as you did above. Either a flipped screen or no emulation station :-(
We would be grateful for any tips.
Cheers Jan
