Pico Display Micropython library without using the firmware
I would like to use the Pico Display with the standard Micropython firmware (Pico W) from Raspberry Pi, rather than the Pimoroni firmware. Is it possible to install the relevant library for the display?
If you do an online search for st7789 Micro Python Library, you’ll likely find something you can use. I do believe the Pimoroni library is C wrapped in Micro Python. And its now Pico Graphics, versus separate libraries for each display.
Did you get this sorted?
Yes, I did thank you. In fact I now switched back to the Pimoroni firmware and it works well.
