Pico Display library instead of complete firmware?
I’d like to use the Pico Display with some other micropython based firmware (in the current case Anvil | Anvil on the Pico W). Is that possible?
TIA
Should be doable with an st7789 Micro Python library. The LCD Display part anyway. The buttons and RGB LED should be doable too, with a little work.
Thanks for the pointer. Will look into it.
