OK I have a PicoW, a GFXPack and a BME688 (PIM575) breakout.
The demo code is:
micropython/examples/gfx_pack/thermometer.py.
import machine
from gfx_pack import GfxPack
from breakout_bme68x import BreakoutBME68X, STATUS_HEATER_STABLE
GFX temp DEMO
This demo uses a BME680 or BME688 attached to the QWST connector to
measure temperature, pressure, and humidity and display it on the GFX display,
or the internal temperature sensor can be used in place of the
BME68x breakout. Just change use_bme68x_breakout to False
# Settings
lower_temp_bound = 15
upper_temp_bound = 30
use_bme68x_breakout = True
sensor_temp = machine.ADC(4)
conversion_factor = 3.3 / (65535) # used for calculating a temperature from the raw sensor reading
gp = GfxPack()
gp.set_backlight(0, 0, 0) # turn the RGB backlight off
display = gp.display
display.set_backlight(0.4) # set the white to a low value
if use_bme68x_breakout:
bmp = BreakoutBME68X(gp.i2c)
display.set_pen(0)
display.clear()
display.set_font("bitmap14_outline")
# Clear display
display.set_pen(0)
display.clear()
display.set_pen(15)
display.text("GFXPack Temp demo", 0, 0, scale=0.1)
temperature, pressure, humidity, gas, status, _, _ = bmp.read()
display.text("Temp: {:0.2f}c".format(temperature), 0, 20, scale=0.2)
display.text("Press: {:0.2f}Pa".format(pressure), 0, 35, scale=0.2)
display.text("Humid: {:0.2f}%".format(humidity), 0, 50, scale=0.2)
heater = "Stable" if status & STATUS_HEATER_STABLE else "Unstable"
print("{:0.2f}c, {:0.2f}Pa, {:0.2f}%, {:0.2f} Ohms, Heater: {}".format(
temperature, pressure, humidity, gas, heater))
else:
reading = sensor_temp.read_u16() * conversion_factor
temperature = 27 - (reading - 0.706) / 0.001721
display.text("Temperature", 25, 15, scale=0.2)
display.text("{:0.2f}c".format(temperature), 25, 30, scale=2)
if temperature < lower_temp_bound:
r = 0
b = 255
elif temperature > upper_temp_bound:
r = 255
b = 0
else:
r = (temperature - lower_temp_bound) / (upper_temp_bound - lower_temp_bound) * 255
b = 255 - ((temperature - lower_temp_bound) / (upper_temp_bound - lower_temp_bound) * 255)
gp.set_backlight(r, 0, b)
display.update()
time.sleep(0.2)
Question 1. How do I insert a degree symbol (Unicode U+00B0)?
Question 2. How do I display pressure as hPa (which is what is used in barometers)?
Question 3. How do I display the air quality from the BME688?
Question 4. How do I correct pressure for sea level?
Question 5. How do I get a more accurate temperature reading (readings at off by +2 degC)?
Andrew
