Hi All,
I have an RPi Pico and a motor SHIM (link) that has been flashed with the pico-v1.25.0-pimoroni-micropython.uf2 from the GitHib repo.
Before playing with some motors, I thought I’d work through some of the API docs, but failed at the first hurdle - reading the state of the button on the SHIM. It’s failing to import picomotorshim, despite that line being a cut & paste from the API docs.
Listing the modules in the shell using help(“modules”) shows up a motor module, along with a couple of other modules with pimoroni in the name. As far as I understand it, that suggests the board has been flashed with the pimoroni uf2.
That said, the API docs were last updated 3 years ago, so if they are out of date are the any pointers to where I can find a more recent description of the modules and how to use them?
