Hey,
I try to make a simple watch…
Again, I have problems with buttons X and Y…???
Maybe it’s due to uasyncio…
So I use only 2 buttons… But I want manpulate the 3 rgb canal of colors…
So more than 2 buttons could be much more better…
If someone can help me…
My code:
from machine import I2C, SPI, Pin
import uasyncio
import st7789
from pimoroni import RGBLED
from time import localtime
import vga1_16x16 as font
##buttons
A = Pin(12,Pin.IN,Pin.PULL_UP)
B = Pin(13,Pin.IN, Pin.PULL_UP)
X = Pin(14,Pin.IN,Pin.PULL_UP)
Y = Pin(15,Pin.IN,Pin.PULL_UP)
button = Pin(23, Pin.IN, Pin.PULL_DOWN)
#rgb led
led = RGBLED(6, 7, 8)
ledi = 1 ## rgb led state on/off
ledu = (0,5,7) ##rgb led color
r,g,b = ledu[0],ledu[1],ledu[2]
led.set_rgb(r,g,b)
colori = st7789.color565(0,255,255) ###for have the number 0 in the same color of the rgb led that you could choice
placi = 0
async def color_choice(r,g,b):
global colori, ledu
colori = st7789.color565(r,g,b)
ledu = (r,g,b)
led.set_rgb(r,g,b)
##lcd display
spi = SPI(0, baudrate=60000000, polarity=0, phase=0, sck=Pin(18), mosi=Pin(19),miso=Pin(16))
lcd = st7789.ST7789(spi,135,240,reset=Pin(29, Pin.OUT),cs=Pin(17, Pin.OUT),dc=Pin(16, Pin.OUT),backlight=Pin(20, Pin.OUT),rotation=0)
stato = 1 ##lcd state on/off
backi = 0.5 ##lcd backlight intensity(float number between 0 and 1)
tempo = 1
async def disp():
global stato, colori, tempo
if stato == 1:
t = localtime()
heure, minute = t[3], t[4]
lcd.fill(0)
uasyncio.create_task(affichage(heure,20, 25, 5))
if tempo == 1:
for i in range(10):
lcd.vline(20+i*10, 115, 5, colori)
tempo = 0
else:
tempo = 1
uasyncio.create_task(affichage(minute,20, 150, 5))
await uasyncio.sleep_ms(500)
if X.value() == 0:
if stato == 1:
stato = 0
lcd.backlight(0)
backi = 0
if B.value() == 0:
if stato == 1:
stato = 2
else:
stato = 1
if stato == 2:
global ledu, r, g, b, placi
lcd.fill(0)
if placi == 0:
lcd.fill_rect(10,2,5,20,st7789.WHITE)
lcd.text(font, "R: {}".format(r), 20, 2, st7789.WHITE, st7789.BLACK)
if placi == 1:
lcd.fill_rect(10,40,5,20,st7789.WHITE)
lcd.text(font, "G: {}".format(g), 20, 40, st7789.WHITE, st7789.BLACK)
if placi == 2:
lcd.fill_rect(10,80,5,20,st7789.WHITE)
lcd.text(font, "B: {}".format(b), 20, 80, st7789.WHITE, st7789.BLACK)
lcd.text(font, "Color565", 2, 120, st7789.WHITE, st7789.BLACK)
global colori
lcd.text(font, str(colori), 2, 150, st7789.WHITE, st7789.BLACK)
hexi = str(hex(colori))
lcd.text(font, "ColorHex",2, 180, st7789.WHITE, st7789.BLACK)
lcd.text(font, str(hexi), 2, 210, st7789.WHITE, st7789.BLACK)
lcd.text(font, "boot for save", 2, 230, st7789.WHITE, st7789.BLACK)
if button.value() == 0:
stato = 1
if Y.value() == 0:
stato = 1
if X.value() == 0:
r += 10
if r > 255:
r = 0
if A.value() == 0:
g += 10
if g > 255:
g = 0
if B.value() == 0:
placi += 1
if placi == 3:
placi = 0
uasyncio.create_task(color_choice(r,g,b))
async def main():
while 1:
uasyncio.create_task(ledron(r,g,b))
uasyncio.create_task(disp())
await uasyncio.sleep_ms(5000)
async def ledron(r,g,b):
if A.value() == 0:
global ledi
if ledi == 1:
ledi = 0
led.set_rgb(0,0,0)
else:
ledi = 1
if ledi == 1:
led.set_rgb(r,g,b)
##font design
async def space(a,b,scale):
pass
async def number_0(a,b,scale):
global colori
for i in range(3):
lcd.hline(a,b+i,9*scale,colori)
for i in range(3):
lcd.hline(a,11*scale+b+i,9*scale,colori)
for i in range(3):
lcd.vline(a+i,b,12*scale,colori)
for i in range(3):
lcd.vline(8*scale+a+i,b,12*scale,colori)
async def number_1(a,b,scale):
for i in range(3):
lcd.vline(4*scale+a+i,b,12*scale,st7789.color565(255,255,255))
async def number_2(a,b,scale):
for i in range(3):
lcd.hline(a,i+b,9*scale,st7789.color565(255,255,255))
for i in range(3):
lcd.hline(a,6*scale+i+b,9*scale,st7789.color565(255,255,255))
for i in range(3):
lcd.hline(a,11*scale+i+b,9*scale,st7789.color565(255,255,255))
for i in range(3):
lcd.vline(a+i,7*scale+b,5*scale,st7789.color565(255,255,255))
for i in range(3):
lcd.vline(8*scale+a+i,b,7*scale,st7789.color565(255,255,255))
async def number_3(a,b,scale):
for i in range(3):
lcd.hline(a,b+i,9*scale,st7789.color565(255,255,255))
for i in range(3):
lcd.hline(a+3*scale,6*scale+b+i,6*scale,st7789.color565(255,255,255))
for i in range(3):
lcd.hline(a,11*scale+b+i,9*scale,st7789.color565(255,255,255))
for i in range(3):
lcd.vline(8*scale+a+i,b,12*scale,st7789.color565(255,255,255))
async def number_4(a,b,scale):
for i in range(3):
lcd.vline(a+i,b,9*scale,st7789.color565(255,255,255))
for i in range(3):
lcd.vline(5*scale+a+i,b+5*scale,6*scale,st7789.color565(255,255,255))
for i in range(3):
lcd.hline(a,8*scale+b+i,9*scale,st7789.color565(255,255,255))
async def number_5(a,b,scale):
for i in range(3):
for i in range(3):
lcd.hline(a,6*scale+b+i,9*scale,st7789.color565(255,255,255))
for i in range(3):
for i in range(3):
lcd.vline(a+i,b,7*scale,st7789.color565(255,255,255))
for i in range(3):
lcd.vline(8*scale+a+i,6*scale+b,6*scale,st7789.color565(255,255,255))
async def number_6(a,b,scale):
for i in range(3):
for i in range(3):
for i in range(3):
for i in range(3):
lcd.vline(a+i,b,12*scale,st7789.color565(255,255,255))
for i in range(3):
async def number_7(a,b,scale):
for i in range(3):
lcd.hline(a+2*scale,b+i,5*scale,st7789.color565(255,255,255))
for i in range(3):
lcd.hline(a+3*scale,5*scale+b+i,6*scale,st7789.color565(255,255,255))
for i in range(3):
lcd.vline(6*scale+a+i,b,12*scale,st7789.color565(255,255,255))
async def number_8(a,b,scale):
for i in range(3):
for i in range(3):
for i in range(3):
for i in range(3):
for i in range(3):
async def number_9(a,b,scale):
for i in range(3):
for i in range(3):
for i in range(3):
for i in range(3):
for i in range(3):
async def point(a,b,scale):
for i in range(3):
lcd.vline(3+a+i,b+9*scale,3*scale,st7789.color565(255,255,255))
async def points2(a,b,scale):
for i in range(3):
for i in range(3):
lcd.vline(3+a+i,b+5*scale,3*scale,st7789.color565(255,255,255))
async def conversion(symbol,a,b,scale=1):
symbol = str(symbol)
a = str(a)
b = str(b)
scale = str(scale)
liste_noms_symbols = ["space", "point","points2","number_0","number_1","number_2","number_3","number_4","number_5","number_6","number_7","number_8","number_9"]
liste_symbols = [" ", ".",":", "0", "1", "2", "3", "4", "5", "6", "7", "8", "9"]
for i in liste_symbols:
if i == symbol:
phrasi = "uasyncio.create_task(" + liste_noms_symbols[liste_symbols.index(i)] + "(" + a + "," + b + "," + "scale=" + scale + "))"
convert = eval(phrasi)
return convert
async def affichage(numbers,a,b,scale):
numbers = str(numbers)
sautx_8 = [" ", ".",":"]
sautx_11 = ["0", "1", "2", "3", "4", "5", "6", "7", "8", "9"]
for i in numbers:
i = str(i)
if i in sautx_8:
uasyncio.create_task(conversion(i,a,b,scale))
a += 6*scale
if i in sautx_11:
a += 11*scale
uasyncio.run(main())
