I absolutely love how the pimoroni presto looks.
But it’s always slightly confused me when screens (and especially touchscreens) don’t come in a case. With a raspberry pi or a plasma2040, you’re probably going to put it inside a box once it’s up and working (and the size and shape of the box is not too important because it’s not going to be as visible). But if you’ve got a touchscreen, it’s likely that people will be touching it at some point, so it’s going to need a case… (and, if the front of your device is made of beautiful brushed aluminium, it’s going to be hard for me to make a case for the back that looks as good).
And I’ve spend a lot of time making cases for screens already!
I especially think that presto is more of a polished device than a normal cheap touchscreen (or something crazy like the Pico GFX), so it really would make sense to give it a proper finish on the back. Right now it seems to be in the no-man’s-land between a maker’s project, and a “real” product. Also, if the USBC was soldered so that it pointed out of the bottom of the PCB, that would be amazing.
