Pirate audio 3W amp: gpio pin usage
I’m new to the forums.
I’m using the Pirate audio 3W amp [1] in a project with a RasPi 3a+ but i’m finding that i need access to a couple of gpio pins. Not specific ones - any will do, and I don’t need any of the special-purpose pins (I2C, serial, etc.). I was thinking of making a simple breakout board out of a bit of perfboard and a stacking header connector so that i can access them.
Can anyone tell me which pins the amplifier hat uses and/or which are unused and free?
Thanks, Andy.
[1] https://shop.pimoroni.com/products/pirate-audio-3w-stereo-amp
I do believe this is the one your using.
They all likely have the same GPIO pinout.
There is also this
I used it with my pHat Beat Pirate Radio to add my own Mini Arcade Buttons.
Thanks Alpha! Thats just what I needed.
Andy
Just use a stacking header with the Proto Zero. Female end on the bottom male pins on top.
