Fairly new to raspberry pi but managed to put together the pirate radio and setup vlcradio, which all work great! I have also setup airplay on the same sd card, which allows me to connect via iPhone but doesn’t play audio. Can these two be loaded on the same sd and work together or am I out of luck?
In the mean time, if you run your VLC radio via the online dashboard, it should work perfectly fine as both, so long as you first activate the radio online! :D
I would merge our two threads, but I’m afraid I lack the power! D:
If any mods see this, would you mind doing a quick merge to tidy the forum up? Thanks!
And you can’t use the Apple features from the dashboard, but you can start the radio.
The Airplay feature should work constantly, however, my play/pause button doesn’t work until I initialise the radio functionality by pressing play on the dashboard first.
