Pirate Radio /phat-beat
Aha, quite some time ago, then. It’s possible you could have received an early revision.
I’d be happy to send you a replacement Pi Zero W and pHAT BEAT to see how you get on.
We also have some experimental software for Pirate Radio which eliminates much of the setup process. Just format a blank SD card with SDFormatter and unzip the contents of this file to the root:
http://get.pimoroni.com/pirateradio-v20171113.zip
Then edit wpa_supplicant.conf with your WiFi SSID/PSK.
Well, that’s most kind of you gadgetoid. I would be most grateful, as I like the idea and look of the pirate radio.
I wasn’t angling for you to bail me out to such an extent but I would be well pleased to accept your kind offer.
Many thanks,
jhon.
Same address as your last order?
yes, please.
thanks again.
You’re most welcome! I read through this forum thread and felt your frustration. We’ve all been there!
Order confirmation email should be with you shortly!
Thank you.
I will have a go with the new software.
Best wishes,
jhon.
