Hello,
I have a Pi 4 with Raspberry OS from 01.11.2021
I have added the PirateAudio 3Watt amp and want to install pirateplayer
Raspberry Pi OS Lite
Release date: January 11th 2021
Kernel version: 5.4
Do I need to install the dev environment to use Pirateplayer?
Pip is installed
pip3, too.
python3, too.
when i use
sudo pip install pirateplayer
I get
Looking in indexes: //pypi.org/simple, //www.piwheels.org/simple
Collecting pirateplayer
Could not find a version that satisfies the requirement pirateplayer (from versions: )
No matching distribution found for pirateplayer
And the command for gstreamer on their page
apt-get install libgstreamer1.0-0 gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly gstreamer1.0-libav gstreamer1.0-doc gstreamer1.0-tools gstreamer1.0-x gstreamer1.0-alsa gstreamer1.0-gl gstreamer1.0-gtk3 gstreamer1.0-qt5 gstreamer1.0-pulseaudio
is not working properly.
I installed every package, instead of gstreamer1.0-qt5 because that does not work. Any suggestions?
Thanks for answer
