Hello,
i want to make an system and i dont know what products to choose from the site. Also what is required as extend board or other to be able to connect them
I will list what i need in here.
monitoring part;
a. outside sensors; wind, temperature, rain (distance from pi board, 5 meters)
b. inside sensors; humidity, temperature, uv, atmosferic pressure
c. inside in the soil sensors; humidity, ph, temperature (distance from pi board) 5 meters)
controlling part;
i want to be able to controll the following;
light, water with electrovalve, venting fans and 2 motors to open or close window
This could do most of the monitoring. Weather HAT + Weather Sensors Kit - Pimoroni
Put the hat inside to measure indoor temps, etc. Then wire up a second BME280 using the alternate i2c address, placed outside for outdoor temps etc.
The Grow Hat can handle soil monitoring and auto watering. Three sensors and three pumps. Grow - Pimoroni
You can put more than one Hat on a Pi, providing there are no pin conflicts.
I’ve done it with a Phat Stack. pHAT Stack - Pimoroni
You need to look at this Automation HAT at Raspberry Pi GPIO Pinout
And compare it to this, Grow HAT Mini at Raspberry Pi GPIO Pinout
I don’t see one for the Weather Hat, but it looks like there are conflicts.
If two or more of the hats use the Same GPIO pin for different functions weird things will happen.
