Hello I’m working on a project for school. I’m using Sense Hat on Raspberry pi 3 B to display pixels on led matrix and IMU to get yaw. But the problem is that I’m trying to run IMU when Ubuntu Mate starts (on boot) in ROS. So I made a service that runs python script on boot. But I get an error from service:
If I run script manually everything works fine, but if I run the service I get the same error.
dec 28 01:25:57 pi-mate picobot-start[870]: File “/home/pi/catkin_ws/src/Picobot/picobot_imu/src/picobot_imu.py”, line 22, in gyroData
dec 28 01:25:57 pi-mate picobot-start[870]: sense.set_imu_config(False, True, True)
dec 28 01:25:57 pi-mate picobot-start[870]: File “/usr/lib/python2.7/dist-packages/sense_hat/sense_hat.py”, line 660, in set_imu_config
dec 28 01:25:57 pi-mate picobot-start[870]: self._init_imu() # Ensure imu is initialised
dec 28 01:25:57 pi-mate picobot-start[870]: File “/usr/lib/python2.7/dist-packages/sense_hat/sense_hat.py”, line 648, in _init_imu
dec 28 01:25:57 pi-mate picobot-start[870]: raise OSError(‘IMU Init Failed’)
dec 28 01:25:57 pi-mate picobot-start[870]: OSError: IMU Init Failed
dec 28 01:25:58 pi-mate picobot-start[870]: No handlers could be found for logger “roslaunch”
dec 28 01:25:58 pi-mate picobot-start[870]: [picobot_imu-6] process has died [pid 1515, exit code 1, cmd /home/pi/catkin_ws/src/Picobot/picobot
Here is my code:
#!/usr/bin/env python
import rospy
from sense_hat import SenseHat
from random import randint
from std_msgs.msg import Float32
sense = SenseHat()
def randomColor():
red_random = randint(0,255)
blue_random = randint(0,255)
green_random = randint(0,255)
return (red_random,green_random,blue_random)
def gyroData():
pub = rospy.Publisher('gyro', Float32, queue_size=10)
rospy.init_node('picobot_imu')
rate = rospy.Rate(10) # 10hz
while not rospy.is_shutdown():
o = sense.get_orientation()
#pitch = o["pitch"]
#roll = o["roll"]
yaw = o["yaw"]
#rospy.loginfo(yaw)
pub.publish(yaw)
rate.sleep()
def main():
sense.clear((0, 0, 0))
sense.low_light = True
g =(0,153,153)
bl = (0,153,0)
b = (0,0,0)
picobot_pixels = [
g,g,b,g,b,g,g,b,
g,g,b,g,b,g,b,b,
g,b,b,g,b,g,g,b,
b,b,b,b,b,b,b,b,
g,g,g,b,bl,b,bl,b,
g,b,g,b,b,bl,b,b,
g,g,g,b,bl,bl,bl,b,
b,b,b,b,b,b,b,b
sense.set_pixels(picobot_pixels)
gyroData()
if __name__ == '__main__':
main()
