I’m using a HyperPixel 4.0 on a Pi 3 A+. I managed to get both the HDMI (with a 720p monitor) and the HyperPixel to work at the same time by adding max_framebuffers=2 to /boot.config.txt.
I’d like both to run in landscape mode, but by default the HyperPixel runs in portrait mode. And if I set display_rotate=1 in the config.txt file, it rotates both displays.
Is there a way to rotate only the HyperPixel display?
The solution is to use display_hdmi_rotate for the HDMI port and display_lcd_rotate for the MIPI port.
But note that 90° and 270° rotates can have a significant performance impact. In my case it was better to rotate the content from within my application (OpenVG + MMAL), at no cost.
