The SD card that came with the kit does not fit the Raspberry Pi as it is too large. What can I do?
The SD card will be an adapter with a micro SD inside it. You can easily remove it with your thumb nail but keep hold of the adapter in case you ever need to use it in one of the older models e.g. a model B Raspberry Pi (I’m assuming you have a model B+ at the moment)
Hope that helps
Lisa
edit: found a pic as an example: http://www.amazon.co.uk/gp/product/B004S1PNE0/ref=ox_sc_act_image_1?ie=UTF8&psc=1&smid=A3P5ROKL5A1OLE
