Servo2040 Robot control(leg)
Hello. I downloaded the pico-v1.25.0-pimoroni-micropython.uf2 file to control the legs of my hexapod robot, and I connected it using Thonny. However, I’m getting an error saying that the servo2040 library cannot be found. I’m not sure what is causing this problem.
Here is my environment:
  • OS: Linux
  • Hardware: Raspberry Pi 5
  • I am writing and running the code through Thonny on the Raspberry Pi.
Additionally, when I connect the Servo 2040 board, the motors do not show the expected rainbow-colored LED effect.
There is another issue: I followed the exact hardware setup from the YouTuber “Make Your Pet,” and the Android-based pre-made app is able to control the robot successfully. But when I try to control the motors through my own code using Servo 2040, it does not connect at all — which is the main problem I’m trying to solve.
Typo in line 2 maybe? the error message is saying “no module named servoi”
Looks like you had an error in the import code.
from servo import Servo, servo2040
#Create a servo on pin 0
s = Servo(servo2040.SERVO_1)
#Enable the servo (this puts it at the middle)
s.enable()
time.sleep(2)
There are more examples here:
