cd 32blit-beta/examples
cd palette-cycle
mkdir build.stm32
cd build.stm32
cmake .. -DCMAKE_TOOLCHAIN_FILE=../../../32blit.toolchain
make
Make sure the 32blit unit is in DFU mode ( hold X and Y then press reset),
it will just show blank screen. Note this is done over USB, no need for an ST Link cable.
sudo dfu-util -a 0 -s 0x08000000 -D palette-cycle.bin
After that, press reset to run the code on the 32blit.
Nice and to the point, much better than having to jump around on git hub to find all the info. In fact I couldn’t find anything in the “docs” that spoke the install of dfu-util and how to flash the device so thank you for putting it all in one place.
When building on linux I am getting the following error:
rnentjes@rnentjes-MS-7B79:~/Development/32blit/32blit-beta/examples/palette-cycle/build.stm32$ make
-- Configuring done
-- Generating done
-- Build files have been written to: /home/rnentjes/Development/32blit/32blit-beta/examples/palette-cycle/build.stm32
[ 73%] Built target BlitHalSTM32
[ 98%] Built target BlitEngine
[ 99%] Linking CXX executable palette-cycle.elf
Building palette-cycle.bin
Building palette-cycle.dfu
/usr/bin/objcopy: Unable to recognise the format of the input file `/home/rnentjes/Development/32blit/32blit-beta/examples/palette-cycle/build.stm32/palette-cycle.elf'
make[2]: *** [CMakeFiles/palette-cycle.dir/build.make:236: palette-cycle.elf] Error 1
make[2]: *** Deleting file 'palette-cycle.elf'
make[1]: *** [CMakeFiles/Makefile2:74: CMakeFiles/palette-cycle.dir/all] Error 2
make: *** [Makefile:84: all] Error 2
Anyone know what the problem is here and how it can be fixed?
Edit: found it, there is a semicolon in an assignment in 32blit-stm32/Makefile:91 which shouldn’t be there…
