I’m trying to get the Pirate Radio working through Balena (formerly Resin)
I’ve tested the hardware using a regular Raspbian image, using curl https://get.pimoroni.com/phatbeat | bash
In Docker, the build fails due to the following: Running as root, please log in as a regular user with sudo rights!
I’ve also tried by installing python-phatbeat via apt-get, but that doesn’t appear to do the ALSA config. /etc/asound.conf is missing and with or without the pHAT BEAT plugged in, there’s only one sound device:
$ cat /proc/asound/cards
> 0 [ALSA ]: bcm2835_alsa - bcm2835 ALSA
> bcm2835 ALSA
How can I install audio support for the pHAT BEAT?
