Ok gents I was taking a wee gander at Tom’s hardware when I encountered this divine creature…
In short when will it be available for the ‘hoi polloi’ “like what I is”? Also, what can we expect stats wise from this microcontroller of - as yet - publicly undefined grace and beauty?
@Caperjack1953 I “think” that 3rd one is a battery charging indicator? If it is that answers my question. @h11t0n if its an RP2040 it has the same specs as a stock PICO. The pinout looks to be the same as a stock PICO. Best guess is its the same size. It would be advantageous for them to make it the same size and pinout as a PICO so you can use it with the Pimoroni PICO Packs etc.
I noticed that the plug for the LED’s he’s using is 4 pin, but the one next to it is only 3 pin?
STEMMA QT (‘cutie’) 4 Pin JST SH - These are smaller 1.0mm pitch connectors
They are for I2C use when the larger JST PH connectors won’t fit on a small sensor board!
I have no idea what the 3 pin one is for? I guess we find out in a day or two?
I totally forgot about the extra flash option. The more of that the better IMHO.
I came close to buying a feather, but then I’d be into getting feather compatible addons etc. I’m not knocking feather, I may actually buy one at some point if the need arises.
I just like the option of using this new LIPO Pico with the Pico packs I already have. Especially the Display Pack. It’s why I haven’t ordered a Tiny, it has a different pinout, and that complicates things for me. The big thing I’m looking for is the ability to recharge the battery when its powered via the USB port. Like the Pico Lipo Shim. I have one of those on the way, should have it in my hands any day now.
That’s a cool way to do it. I’m going to dedicate mine to a PICO. My plan is to remove the black plastic base from around the 8 rows of pins on the PICO, that the LIPO board mates too. That will get it right up next to the PICO with next to no space between them. They may even be touching back to back. The solder won’t be any higher than the plastic base that’s left on the remainder of the pins on the PICO. Any pack I plug in should be snug right up against the plastic base part, and not be affected by the LIPO Board. That’s the plan anyway. I’ll upload picks when I finally get my hands on it.
Yeah I’ve found it a bit awkward to wiggle the Pico out of the Explorer too, it’d be fine if Breakout socket 1 wasn’t right where your finger needs to go.
