I just received a brand new inky phat yesterday and been trying to get it to work without success.
The inky phat arrived with the default logo on it (a bit pink instead of white compared to the photos of the previous version), and I plugged it into a Raspberry Pi Zero W. No matter what example I run it just doesn’t do anything, it hangs. When I try to stop the script with Ctrl+C the traceback is always in the same state:
^CTraceback (most recent call last):
File "cal.py", line 166, in <module>
inkyphat.show()
File "/usr/lib/python3/dist-packages/inkyphat/__init__.py", line 113, in show
_panel.update()
File "/usr/lib/python3/dist-packages/inkyphat/inky212x104.py", line 193, in update
self._display_init()
File "/usr/lib/python3/dist-packages/inkyphat/inky212x104.py", line 102, in _display_init
self.reset()
File "/usr/lib/python3/dist-packages/inkyphat/inky212x104.py", line 238, in reset
self._busy_wait()
File "/usr/lib/python3/dist-packages/inkyphat/inky212x104.py", line 228, in _busy_wait
while(GPIO.input(self.busy_pin) == GPIO.LOW):
KeyboardInterrupt
Shutting down display, please wait...
Then it stays at Shutting down until I Ctrl+C again.
I tried rebooting, made sure the Raspbian version was up to date, waited for one hour, tried executing the python steps on the command line and it’s always the same.
Am I missing something? is there any checks I may perform to identify the problem?
Glad I can help debugging the problem. Here’s the output of both commands:
lsb_release -a:
pi@raspberrypi:~ $ lsb_release -a
No LSB modules are available.
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 8.0 (jessie)
Release: 8.0
Codename: jessie
dpkg -s python-inkyphat:
pi@raspberrypi:~ $ dpkg -s python-inkyphat
Package: python-inkyphat
Status: install ok installed
Priority: extra
Section: python
Installed-Size: 504
Maintainer: Phil Howard <phil@pimoroni.com>
Architecture: all
Source: inkyphat
Version: 0.0.2
Depends: python-numpy, python-pil, python-rpi.gpio, python-spidev, python:any (<< 2.8), python:any (>= 2.7.5-5~)
Suggests: python-requests
Description: python library for the Pimoroni Inky pHAT
Ideal for name badges or displaying statutes and notifications.
This is the Python 2 version of the package.
Homepage: https://github.com/pimoroni/inky-phat
The other thing to try is to carefully unclip the ribbon cable on the back of the Inky pHAT and re-seat it. Slide your fingernail, or a thin plastic spudger under the clip and flip it open, then remove and re-insert the ribbon cable, then push the clip back down.
Other than that, you might see this behaviour if you haven’t updated the software, which needs to be done, for this new board. You can do that by typing sudo pip install --upgrade inkyphat in the terminal.
