Hi, I am building a home arcade machine. I have a X Hat and a speaker connected to it. I am unable to control the volume at all. Any ideas as to what would help would be appreciated.
Are you using a standard RetroPie image, or a pre-made image? Have you installed the XHAT driver? What happens when you try to adjust the volume in Emulation Station, does the % level change at all?
I’m using a Github link. I’ve installed Xhat drivers Via Pimaroni.com
Adjusting volume in emulationstation makes no difference
Your audio needs to be set to PCM in emulationstation.
Thanks. It’s sorted now
