Speaker Phat connection
Hi All,
I just got my speaker Phat, and i want to use it with my Rasp Pi Model B.
I soldered the 20Pin and the two connector wires and then plugged it into the 20 Pin on the Rasp pi, but i dont get any sound
Is this supported, using all 20 pins or is there a different way or doing it
The soldering looks fine, i can send pic of it if needed
thanks for the help
Did you run the one line installer curl -sS https://get.pimoroni.com/speakerphat | bash
From here, https://github.com/pimoroni/speaker-phat
Soldering all the pins is fine. Most of the pads don’t go anywhere or do anything. The ones that count are shown here, https://pinout.xyz/pinout/speaker_phat#
