Hi
What’s the length of the Three Port USB Hub with Ethernet - microB connector ADP005 without cables?
And maybe with cables? It’s to see if it fits a hole in the wall.
Hi
The white plastic case is 9.5 CM long and about 1.5 by 2.5 cm. Your going to want 11 or 12 cm so the cable wont kink if you fold it back. There is a rubber strain relief where it enters the case. The cable itself is about 15 cm long.
Great, I just have 12cm, so that could work. I made the hole for a Beagle Bone Black, but I it’s to small combined with the cables. A Raspberry Pi Zero + Ethernet adapter seems to be the only smaller computer I could find. But it seems that it can fit.
If pinch came to shove, you could carefully cut the rubber strain relief part off with an Exacto knife
