Hello to everyone.
I’m trying to configure the display hyperpixel 4.0 Square Touch that I’ve bought here :
with FreeBSD 14.2 that I have installed on the Raspberry Pi Zero 2W. I’ve used these parameters inside the config.txt file :
overscan_left=0
overscan_right=0
overscan_top=0
overscan_bottom=0
framebuffer_width=720
enable_dpi_lcd=1
display_default_lcd=1
dpi_group=2
dpi_mode=87
dpi_output_format=0x5f026
dpi_timings=720 0 20 20 40 720 0 15 15 15 0 0 0 60 0 36720000 4
I’m using the 40 pins of the GPIO connector :
Some parameter is not correct because the display does not turn on. While it works correctly with Linux for the raspberry pi.
Someone has bought this display and can give some suggestions ? thanks.
