I am trying to use a Pimoroni 240x240 Square LCD with a Raspberry Pi Pico 2. I am using the Adafruit GFX library and the ST7789 driver. I am trying to get it to simply display a white screen, but the only thing it has done so far is turn on. I tried changing the SPI frequency, SPI mode, and bringing the Chip Select pin high, but none of those changes did anything. Here is the code I have right now:
#include <Adafruit_GFX.h>
#include <Adafruit_ST7789.h>
#include <SPI.h>
#define DISP_CS 17 // GP17
#define DISP_RST 21 // GP21
#define DISP_DC 20 // GP20
#define DISP_BL 16
#define DISP_MOSI 19 // MOSI and Serial Clock
#define DISP_SCK 18
Adafruit_ST7789 display = Adafruit_ST7789(DISP_CS, DISP_DC, DISP_MOSI, DISP_SCK, DISP_RST);
void setup() {
// put your setup code here, to run once:
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, HIGH); // Turn on led
pinMode(DISP_CS, OUTPUT);
digitalWrite(DISP_CS, HIGH); // Pull chip select high
pinMode(DISP_BL, OUTPUT);
digitalWrite(DISP_BL, HIGH); // Turn on backlight
Serial.begin(9600);
Serial.println("Program Opened.");
// Initiate display
SPI.begin();
display.init(240, 240, SPI_MODE0);
display.setRotation(0);
display.invertDisplay(false);
display.fillScreen(ST77XX_WHITE);
void loop() {
// put your main code here, to run repeatedly:
draw();
void draw() {
I guess I should probably be using the Pico C SDK, but I prefer Arduino Software over it. Any help is appreciated :D
