I bought a Sparkfun ultrasonic sensor yesterday to use with my Explorer HAT robot. I tested it on an Arduino UNO with this sample code from Sparkfun:
void setup()
  // initialize serial communications
  Serial.begin(9600);
void loop()
  int sensor, inches, x;
  // read the analog output of the EZ1 from analog input 0
  sensor = analogRead(0);
  // convert the sensor reading to inches
  inches = sensor / 2;
  // print out the decimal result
  Serial.print(inches,DEC);
  // print out a graphic representation of the result
  Serial.print(" ");
  for (x=0;x<(inches/5);x++)
    Serial.print(".");
  Serial.println("|");
  // pause before taking the next reading
  delay(100);
The sensor worked fine with the Arduino, outputting an accurate whole number. Then I connected it to the Explorer HAT Pro with 5V, GND, and Analog 1. I used this code:
import explorerhat as eh
    sensor = eh.analog.one.read()
    inches = sensor / 2
    print(inches)
    time.sleep(0.1)
I am getting a different output with the Explorer HAT, a decimal number that is far different than the Arduino. Is my Python program no good, or does the Explorer HAT’s analog inputs operate differently than an Arduino’s?
