Hello all, I have a little problem with my unicorn-hat and I would like some help if at all possible.
I am using my unicorn-hat with a raspberry pi 3 (running Kali Linux 2.1.2) and it is in the very dashing ninja case.
Now the problem is the unicorn-hat doesn’t light up whatsoever, I have python 2 but whenever I open an example script it just freezes out, I have to press ctrl+z as ctrl+c doesn’t work, and nothing shows on the unicorn-hat at all. However when I plug in the raspberry pi the unicorn hat flicks a few lights across the board and then turns off a split second later.
So? what do you guys think? any ideas?
Thank you so much,
Nathen Davies
