I use touch phat with scroll phat. Touch send command to scroll for display differents datas…
Everything is fine, and so beautiful, with a low consumption… I love it.
I would like to display data wich is saving in a file from a serial connection.
But I don’t success. The “event” seems not able to use a variable from a file that I have to open in the script…
I have tried to use a threading for initiate the variable out of the button_action… without success…
If somebody can tell me if what I want is possible…
And maybe a solution…
Thanks.
PS: my script:
Blockquote
#!/usr/bin/env python
import signal
import sys
import subprocess
from sys import exit
from gpiozero import CPUTemperature
import touchphat
import scrollphat
import threading
import pickle
import numpy as np
scrollphat.set_brightness(2)
scrollphat.set_rotate(True)
def flag():
#time.sleep(3)
event.set()
#print(“event is clear”)
#event.clear()
for pad in [‘Back’,‘A’,‘B’,‘C’,‘D’,‘Enter’]:
touchphat.set_led(pad, True)
time.sleep(0.1)
touchphat.set_led(pad, False)
time.sleep(0.1)
def start_scroll():
event.wait()
while event.is_set():
#print('starting random integer task')
#x = np.random.randint(1,30)
#time.sleep(1)
def string_to_bcd(digit):
bcd_digit = bin(int(digit))[2:]
return ('00000' + bcd_digit)[-5:]
def plot_digit(digit, position):
bcd_digit = string_to_bcd(digit)
for y in range(0, 5, 1):
scrollphat.set_pixel(position, y, int(bcd_digit[y]) == 1)
try:
current = time.strftime('%H0%M0%S')
for x in range(0, 8):
plot_digit(current[x], x)
for i in range(0, 5):
scrollphat.set_pixel(10, i, (5 - i) <= ((int(current[3:5])) / 10))
scrollphat.update()
time.sleep(0.5)
except KeyboardInterrupt:
scrollphat.clear()
sys.exit(-1)
def start_touch():
event.wait()
###touche A pour affichage heure
@touchphat.on_release(‘A’)
def handle_touch(event):
scrollphat.clear()
dati_now = time.strftime(" %H:%M ")
scrollphat.write_string(dati_now, 11)
length = scrollphat.buffer_len()
for i in range(length):
try:
scrollphat.scroll()
time.sleep(0.1)
scrollphat.clear()
sys.exit(-1)
###touche B pour lancer affichage date
@touchphat.on_release('B')
scrollphat.clear()
date_now = time.strftime(" %m/%d ")
scrollphat.write_string(date_now, 11)
try:
scrollphat.scroll()
time.sleep(0.1)
scrollphat.clear()
sys.exit(-1)
###touche C pour lancer affichage temperature cpu
@touchphat.on_release('C')
scrollphat.clear()
cpu = CPUTemperature()
tempe = str(cpu)
cpuu = tempe[44:48]
cpuuu = float(cpuu)
message = " " + cpuu + "C "
scrollphat.write_string(message, 11)
try:
scrollphat.scroll()
time.sleep(0.1)
scrollphat.clear()
sys.exit(-1)
###touche D
#@touchphat.on_release('D')
#def handle_touch(event):
###touche return pour arreter l'ordi
@touchphat.on_release('Back')
subprocess.check_call(["sudo shutdown +1"], shell=True)
###touche return pour sortir de la boucle ou du script
#@touchphat.on_release('Enter')
signal.pause()
event = threading.Event()
t1 = threading.Thread(target = flag)
t2 = threading.Thread(target = start_touch)
t3 = threading.Thread(target = start_scroll)
t1.start()
t2.start()
t3.start()
#print(“event has been cleared, random operation stop”)
Blockquote
