Veml6075 MicroPython driver?
Traceback (most recent call last):
  File "<stdin>", line 12, in <module>
ValueError: BreakoutLTR559: Bad i2C object
Line 12 is ltr = BreakoutLTR559(i2c)
#import machine
from machine import I2C, Pin
sda=machine.Pin(4) # Explorer 20 Breakout 4
scl=machine.Pin(5) # Explorer 21 Breakout 5
i2c=machine.I2C(0,sda=sda, scl=scl, freq=400000)
import veml6075
import machine
from breakout_ltr559 import BreakoutLTR559
uv = veml6075.VEML6075(i2c)
connected = uv.initUV()
import picodisplay2 as display2
display_buffer = bytearray(320 * 240 * 2)  # 2-bytes per pixel (RGB565)
display2.init(display_buffer)
display2.set_backlight(0.8)
    reading = ltr.get_reading()
    #print("Lux:", reading[BreakoutLTR559.LUX], "Prox:", reading[BreakoutLTR559.PROXIMITY])
    light = reading[BreakoutLTR559.LUX]
    display2.set_pen(0, 255, 0)
    display2.text("sun", 0, 70, 240, 3)
    #Convert light level in lux to descriptive value.
    if light < 50:
        display2.text("dark", 60, 70, 240, 3)
    elif 50 <= light < 100:
        display2.text("dim", 60, 70, 240, 3)
    elif 100 <= light < 500:
        display2.text("light", 60, 70, 240, 3)
    elif light >= 500:
        display2.text("bright", 60, 70, 240, 3)
    UVI, UVIA, UVIB = uv.readUV()
    #display2.text("uv", 0, 70, 240, 3)
    display2.text("UVIA         {0:.1f}" .format(UVIA), 0, 180, 240, 3)
    display2.text("UVIB         {0:.1f}" .format(UVIB), 0, 200, 240, 3)
    display2.text("UVI avg    {0:.1f}" .format(UVI), 0, 220, 240, 3)
    display2.update()
    display2.set_pen(0, 0, 0)
    display2.clear()
    time.sleep(1.0)
