My son and I just completed assembly of the line following robot, following the video instructions (great video - easy to follow!). The video mentioned a follow up video to explain the software side of the project but I can’t find anything.
We tried flotil.la/cookbook but there are only two ‘recipes’ there - where is the line-following robot recipe?
Cheers
Peter
Anyone? How did this come with absolutely zero instructions on how the rockpool interface works?
- Read the Getting Started Guide (pdf) on the Flotilla github.
- Download the software to a Pi with the curl command given.
- Plug the Octopus dock into the pi, and some inputs (switches) and outputs (lights) into the dock
- Watch the Bilge Tank episode on YouTube and it’s clear from that that you just have to…
- connect to the dock through http://flotil.la/rockpool. the 127.0.0.1 is if it’s directly connected, or let it scan or enter IP address of Pi if known.
- Click on + by Input to add an input (if you;ve one plugged in) and + by Outputs.
Hope you have fun from there.
Nick
